Trophy #199
neil a
I stuck a few pictures up in my other thread , but as this one is a clio so thought I would give it’s own post in here.
After selling trophy #57 around 5 years ago, just before the big price hike I thought I would never have another due to the cost now.
I originally set out to look for a 172 cup to have as a long term resto, I was talking to Stu from Renomotive and well one thing led to another and I ended up buying his Trophy.
It’s a well used car that’s lived a life 😂 including light front end damage when it was only a couple of years old.
Renomotive had looked after the car for the previous owner before buying it. It was then used for daily use and a Nürburgring trip, it has had a lot of mechanical work but cosmetically it needs a full repaint ideally.
Before picking it up from Stu , I had Sponge from on here to give the car a full cut to try and bring it back to red as the car was pink.
He worked his magic and made the car useable again until I look at paint next year.
The passenger wing and door had bad previous paint which couldn’t really be saved , so a replacement door and wing was soured and fitted this week.
Inside is fairly tidy bar a well worn Sabelt wheel, that I’m going to attempt to save.
I’ve also never liked the basic trophy rear bench so have fitted a half leather one with headrests.
You can see how far off the previously painted door was it sort of faded from dark red to trophy red.
Wheel re fitted along with a BMS shifter.
Just new dash trim strips to go and the interior is how I want it.
The only issue I have is a SERV light on the dash I’m guessing this is cause it’s had a screen fitted in the past with no auto wiper sensor. I’m unsure if this can be coded out to clear the light.
No auto wipers on trophy. Povo as fook!
Soon find out what serv light is on for with a quick scan with clip.
Ah that makes sense couldn’t mind if my last one had auto wipers or not.
I don’t have clip sadly , do you know if any other scanners will pull it.
Renolink will work. Maybe delphi. Worth asking if anybody local has clip, prob airbag related at a guess.
If your passing Middlesbrough at any point, give me a shout and i can plug it in.
I think I now know the issue after talking to Renomotive yesterday. The car got a low mileage engine for the a while ago along with 438 cams and mapped ecu/uch thus all came from a ff 182 so will need the auto wiper sensor coded out as will be looking for something that doesn’t exist.
Still not got round to trying to work out how to use clip to remove the auto wiper function
First issue is finding a laptop with disk drive to upload the software :ROFLMAO:
I did get a new wheel sorted though , ended up sending my standard wheel to Snappy so will be getting that fitted up soon.
Snappy's work is always so good!
Pretty sure he worked for Bentley in the past(?).
Had a wheel from him on my old inferno cup. Though the top stripe did colour fade due to the harsh Aus UV.
Whats the reasoning for moving away from the 330mm cup steering wheel?
Going back to a more factory look mainly , and I also prefer the slightly larger wheel for on the road.
During the cold weather the clio had been a pain to start, and also threw a lambda code. Stuck a new sensor in it and it’s a lot better but think the cold start on the map isn’t the best. When RS did the mapping on the engine in a previous car it was track only so cold start probably wasn’t a priority.
I’ve also had an alignment on it to dial out a bit tow a front camber. It’s still showing a lot of camber on the rear so guess Stu had shims fitted for a previous ring trip.
I will probably remove them and fit some axle stub spacers at some point.
Trophy is due an MOT soon so thought I best try and get the SERV light off the dash. Cant seem to find anyone with CLIP in Scotland that still works on older models.
I did drive 1.5 hours the other day to a garage that thought they could code it out but no luck 😔
Ive noticed a knock coming from the front end at low speed which looks to be the offside front top mount. I also think the front shocks could do with another rebuild. I decided to fit a set of B14’s and shelf the original shocks until I do a refurb on the car.
Decided to switch the suspension over today , cleaned up the shocks and gave them a coat of preservative.
Stupidly started at the back then found out I had been sold 54mm fitment not the confirmed 60 🤬
You can just oval them to be fair, you can even see the top hole where they'd be punched out for 60mm
