2011 Clio 1.2 TCE Misfire
Car  2011 Clio 1.2 TCE
Hi all,
Just after some advice, my partners clio went into limp mode a couple of weeks ago and has been off the road, it’s had new coil pack, new leads and 4 new plugs. All plugs except cylinder 3 came out clear, the plug in C3 was black. It’s still misfiring so I’m thinking injector? Interestingly I fired it up yesterday and it’s giving me a code for cylinder 2 misfire now instead of 3 so I’m a bit stumped. I was only going to change the 1 injector for now as funds are a bit tight.
Is this something I’d be able to do myself? Looks like I’ll need to remove the intake pipe covering it but the fuel rail doesn’t look too hard to get at.
From what I know it’s the D4FT 1.2 100hp
Any advice would be appreciated!
You can try swapping injectors around to narrow down the exact problem. Very easy to do if you're competent with a spanner.
Black plug sounds a bit like an over fueling issue.
Could probably look for some second hand plugs from a breakers if money is a bit tight.
