1.2 16V (04 plate) PCV Breather hose/ pipe?
  RenaultSport 197
Hello all, Im new to this, so you'll have to bear with me!!
Is there a breather pipe from the PCV oil filter or crankcase on the 1.2 16v Dynamique? I have an Apiro breather filter that i was given as a sample for thier products and i want to try it out. Obviously it needs to be fitted onto a breather pipe, but apart from the air filter i cant find naff all.
So any ideas where the breather pipe is?
Also on the crankcase (directly under the air filter) there is what looks like a 7 or 8cm piece of pipe that comes out of the crankcase but has a stop valve or a non-return looking valve. Is that the pipe?
Thanks guys! :D
M
mini-valver
Im not familiar with the 1.2 16v engine but the breather filter your taking about goes on the oil breather pipe that goes into the air filter assembly.
Not sure on the thing you mention below the air filter but the crankcase breather system on the 1.2 is all internal running up into the cylinder head then the cam cover has some weird cut outs to get them up into the airflow.
  RenaultSport 197
I went to a Reno garage and they dont have a fooking clue!! You would of thought they could at least point out the internals. So, I still cant find the correct hose to put the filter on.
Are there any other Breather pipes in the 1.2 Clio?
