1.2 8v cambelt issues
Car  Ultra Red Megane 225
has anyone ever done a cambelt on one of these? Ive only got w/s manuals for the F4R engine so havent got a clue about timing it up etc.
Any tips or tricks?
Any help will be very much appreciated.
id already thought about that one, trouble is the cambelt has broken so i have to re-time the engine. thats after ive replaced any bent valves etc etc etc
Cam pulley has a mark that points at 12 o'clock and the crank pulley has a mark that points at 6 o'clock.
Your new timing belt should have 2 white lines on it, the whit lines line up with your 6 and 12 o'clock marks!:cool:
They r piss easy. Mark on topcam should b at 12 oclock, bottom at 6 oclock, also shoulda markson flywheelnear tdc sensor. If all else fails remove spark plug in number1 cylinder and check the position of the piston. it shouldb at the top.
