1.2 8v running problems
Car  2007 clio dynamique
hi there my sister has just bought a clio 1.2 8v and its running really rough, theres a misfire and it hesitates very badly my thought is that its the coil pack but i am not sure as it could be the leads i just wondered if anybody could give a definate answer ? its definately not the plugs though as they are brand new also when braking the abs kicks in on the passenger wheel even at low speeds could this be the abs ring ? any help would be appreciated thanks
I think you have got it pretty much covered there, coil pack is definitely a good first call. If you know anyone else with the same clio see if you can swap them over, its fairly straightforward and it saves forking out for one straight away. As for the abs i dont really know much about the system tbh but the ring or the sensor perhaps.
