1.2 gearbox oil
Car  182
hi was wondering what oil for my gearbox :) 1.2 51reg. And was wondering if anyone knows how much the plastic screw Is. And what sump plug I'll need washer etc
75w 80 for the gear box, the plastic filler hole screw wont need replacing unless its stripped, the sump bolt shouldnt need replacing, just get a new washer from renault
The screw kinda has foam washer on which is not in the best of condition haha. Need a recommendation on what oil to put in tbh /:
If the plastic washer is damaged you could make another one, or order it from a dealer, as for oil, been using castrol oils in the car its whole life with no issues, the grade will be 75w 80...
Millers EP GL5 75w80 is what i put in my 1.2 a while back, seems decent nothing has blown up ;)
