99 Clio 1.2 Grande
Hey all
Technical assistance required off some experienced persons please!
I have a T reg 1.2 8V which runs fine when cold, but when warm/hot decides to run very badly, will not accelerate cleanly (hesitates etc) and if you come to a stop, will cut out and refuses to re-start.
I don't know wether this is connected, but the car was fine before I,
a) Changed the thermostat (over-heated as the cooling fan didn't work)
b) Removed the relay for the fuel pump checking the relay for the cooling fan.
Also, sometimes the car will not deactivate the immobiliser, hot or cold, (don't have another operational key to swap with).
Can anyone shed any light? SWMBO is loosing faith with the little beast.....
Thanks for any info!
John.
John.
