I love my DCi 65 had it for 2 years now and its still going strong
i love the oil bunnies, yes MPG yes insurance
but then theres servicing costs and the price of diesel too.
Absolutely Edde.
Theres so much misinformation put about about diesels.
As its said " A little knowledge is dangerous".
i must admit the only races i've had with diesels were agains the A4 1.8 td's and modeo 1.9 cdti
both slower than my car.
i followed dangermouse_se in his diesel to bridlington one year and that was in the way, but i had to get some serious speed up before being able to pull past.
im sure alot of it is down the the drivers.
so why eddie aint all car manufacturers make so called large power band diesels. are these not gonna last for as many miles at the old diesels?
If you class your Dci as slow i guess there must be something wrong with it!!!
Anyway who wants to drive at 5000 to 6000 rpm to release the optimum torque and bhp. As per Eddes post.
Yeah with the induction kit the sound of the 1.2 adds to the driving experience for sure. Adds to the sense of speed and fun.
Yeah I just tried to keep it at 4000rpm to get max power all the time. And braking hard and late etc.
Yeah I will get a DCI as I cannot afford not to! My petrol bill is just over 300 quid a month and I am still in sixth form earning 400 a month!
I must admit I was under the impression power (for cars) is measured in BHP or PS. Max BHP and PS comes at around 4000rpm on clio diesels. Thereby revving the car to 4000rpm and keeping it there utilises the maximum possible proportion of the engines power.
Correct me if I am wrong by all means.
If I down sized to a cheaper car I'd probably go for a diesel of similar spec to the one I had. Feels like a 2.0 at normal every day speeds. Only when you try to drive "fast" do you realise it isnt.
The quote doesn't tell us anything.
the top of the speed range is a relative term. This is to say that a petrol at 6000rpm will produce a higher proportion of total max power here than diesel at 6000rpm. But what I am saying is that to get the diesel moving fastest in a clio you need to play in the max POWER (as in max BHP output) range (4000rpm).
Are you telling me to get to 100mph quickest in your DCi you would not rev it to 4000rpm (max power)? Are you telling me you would change in such a way as to utilise the engines torque most efficiently, i.e. 2500rpm or whatever it is?
Sam
That means that it is better changing gear just before the engine looses power. And that point is not max RPM.
Ulle you are wrong. 4K is the general point at which you should change if racing. You don't want to take it above that but its really where you want to be.
Ok had the test drive.
To conclude I liked the engine, covered ground much quicker than mine, however due to the lack of sound and high revs it was nowhere near as fun. However due to the extra fuel savings I will go with the diesel me thinks.
P.S. I only got 27mpg as I drove it (this better not be the bloody case everyday if i get one or else it isn't worth changing)
Sam
I said good power band, not just powerBar the 318d, BMW have strong diesels in every class, the 204bhp 3.0 diesel was for example, the fastest production diesel on the road. Faster than Audi's 4.0TDI, and VW's V10 touareg. And now there is the 335d... Insane let me tell you, however it's auto only, not a massive problem, just a bit annoying at times and not nearly as involving.
VAG diesels are running 5 year old technology, even my Clio has something they don't.. Common rail. But then again Audi like to sit in the dark ages with a lot of things.
Because they prefer there technologyWhy aren't VAG diesels running common-rail yet? Is there a reason behind it?
yes, almost identicle engineAs for the engine itself (it was an DCi 86, of course the new shape which I don't want but the engine, I am informed, is very similar to the DCi 80):
you need to rev the diesel, it just feels quick at low RPM due to the way power is designed to arriveThats just so wrong ! You don't get max power at high RPM's ! If you think so, you should not drive a diesel car ! Max power is always from the low RPM's where the torque is highest. Maxing out a diesel car wont get you flying ...
no your right, you just have to remember to use the peak horse power curve, so 3 to 4K usuallyI must admit I was under the impression power (for cars) is measured in BHP or PS. Max BHP and PS comes at around 4000rpm on clio diesels. Thereby revving the car to 4000rpm and keeping it there utilises the maximum possible proportion of the engines power.
depends on the engine, on mine its 4.2K in 1st then about 4K in the rest of the gearsJust a question, what RPM should I be changing my gears in my DCi if im giving my mate a little race on the dual carrageway? cheers![]()
You want maximum power so maybe change up at 5k, whilst you might be way out of power when you change up you'll oly be down to sat 3k wheras changing up at 4k would pust you at say 2k.surly if your engine is producing maximum power at 4k, u dont wanna be putting the clutch in and changing gear at that point. surly ur gonna be wanting to be in gear at maximum power, u gotta change when it the accleration/rpm curve gets a neutral or negative rate of change!
NO?
this is why i like the petrol. just change when it starts limiting, easy!
