1.4RT Thermostat location ?
rctempire
To the right of the engine block. Look for where the water hose goes into the engine (right hand side of engine).
The L bend bracket contains the thermostat.
Hope that helps.
The bend wil also have the tube for the Header take return attached to it.
  L Reg Clio RT, Polo X 2
Cheers mate . You my friend are a legand
I asume it will be a straight swap ?
Pull in Pull out Jobby ?
Il have to pop down to GSF *German Sweedish French Carparts
Thanks agin for the help
rctempire
Unbolt the whole unit, then take the thermostat out then change it.
3x 10M bolts to take the whole unit off.
Watch the water will disappear from the system, good idea to drain the car first before taking thermostat off.
GSF should have it yes. However Halfords may also have it.
Thamks for mentioning the draining the coolent first i think i could of gotten very wet !
Were is the best place to drain the coolent form in the 1.4RT ?
Cheers fo rthe swift response again . Your being extreemly helpful .
Thanks for the advice . Will have to crack on with this later today and let you know iff it has solved the problem . GSF have one for £15
