1.5 DCi wouldn't start
Car  1.5 DCi
Get up this morning, -4. Excellent. Goes to start the car, it turns over once, doesn't fire then just clicks.
So I remove the keys and try again, only to receive the same result.
Fortunately for me I was parked on a hill, and managed to bump it down the hill.
Any ideas what might be causing this to happen?
Thanks in advance...Chris.
So change the battery and hey presto?
I've read a few stories about fuel pumps shitting themselves, and injectors failing on these engines. Not really sure how to diagnose what the actual problem is.
How do I read fault codes? Can I read them on the dash with a pedal test of some sort?
Dude, battery! If it started by bumping it and then ran fine its not going to be fuel pump etc. Batteries die in this weather.
I did think battery as soon as it happened, as it's happened with my Corsa I had a few years back in the winter. Looks like original battery too so 11years use is well over what they're predicted to do anyway.
I'll get a new battery tomorrow and get it fitted, hopefully it'll be problem solved :)
Thanks for your help!
But still, out of interest, is there any way to read fault codes without a diagnostic machine?
