1.6 modded and non modded
Car  Merc Coupe V6 AMG
was wondering what speed you can get out of 2nd gear and what rpm?
please state whether you are not modded please, vice versa
thanks alot need to know how my progress is going and my ratios are.
6250rpm is about 57 indicated, won't take it to the limited as i'm too much of a girl. Not modded (yet).
o yeh they do an older 8v valve to, slipped my mind. ^^^ interesting as the other guy got 57 at 6700 you must have one of the lucky ones. are you lot starting from 0 through 1st gear? as i had a rolling start in 2nd from about 30, i think i need to do it form 0
shouldnt make a difference ^ my 1.2 manages to do 59 in second at red line..whatever that is .. :P
think top speed in each gear is like this for both 8v and 16v
1st - 29
2nd - 58/59
3rd - 80
4th - 101
5th - 120
and as far as I am aware other than the rsi's, valvers, william 1*2's and v6's they all use the same ratios
aye...mine is similar to that ^ not sure of 4th gear redline and 5th varies, usually around the 110
might go wash my car
its a bit dirty and i need to put my back seats back in
mine is
1st 30
2nd 59
3rd 85
4th 110
5th i'd guess at 137
all speeds are indicated by the speedo
It's on the dash at just under 60 so ACTUAL speed is probably less, that's why the 0-60 of the 1.6 isn't that good, because of the gear change, if the rev limiter was higher say 7000rpm then 60 should be piss in 2nd.
Mines been timed at 8.8 to 60, so Your right, I don't really care about it TBH.
Lol, I thought you we're being sarcastic!! lol
10.5's pretty good for a 1.2 16v, it's the book time for a 1.4 16v
I heard somewhere that the (factory) 0-60's are done with two people in the car, half a tank of fuel and a 100k payload.
