1.9DTI con rod specs? info needed
Dr HMS Derv Destroyer
Car  MK1DCi/vivaro/REN’11
hi all , as above, need to know the specs ( messurements of small end/ bigend ect ) of the renault 1.9dti engine con rods...
i am hoping that the specs are the same as a VW 1.9 ahu conrod, as darksides do a forged kit for them,which in turn will be helpful for when i build up this custom engine ( if they match and can be fitted )
ta very muchly
raz
• 144mm center - center
• 26mm tapered small end
• 50.6mm big end
• For use with Stock Pistons or 2.0 Pistons in the 1.9 Engines
• Special profiled so there is no need for grinding in the block
• 2 piece forged from 40CrNiMo steel
• Comes with ARP 2000 bolts and assembly instructions
• Shot peened and heat treated
• Weight is 575 gram with bolts, tolerance of +- 1 gram
hopefully who ever finds the specs, these will match. 400 for the set if so :D
