1 question
  none :(
How much lower is a 172 compared to a normal 1.2 16v
Also would you be able to put standard 172 springs on a 1.2 16v
Quote: Originally posted by nobblebonce on 31 January 2005
whats the difference
The rear springs and dampers will fit and the weight wont be that far off.
But the front is very different seems someone has fitted 1.2 uprated springs to a 172 ok but there just not desinged for a 172. The 172 has to much weight at the front for 1.2 springs to be right stick with the proper springs for the best ride.
Djw John
Scotland - South
a lot!! If you want 172 suspesion you need a 172 engine and whole front end and a 172 rear axle. You can get better aftermarket though such as an APEX kit from www.motorsportworld.co.uk
