100 cell cat
Car  182 cup
Hi hopefully some one has this and will no i have just braught a prospeed exhaust with 100 cell cat is this gonna bring on the dreaded engine managemant light or will i b ok or will it b on and off depending on temperature
i had a 100 cell cat on my 1.6 clio and it did bring up the engine light but that was it
it didn't go into limp mode at all so just drove it with on
Bought.
If it puts the engine management light on you're not going to sort it unless you take the bulb out/ take the lambda sensor out of the exhaust , tie it up under the car and plug the hole up.
Yer will have to do that prob heard mixed things sone which come on and others dnt will have to see is there much tolerance before setting the light of .
