10mm hub centric spacers for 182 - where from?
MadUsa1
Car  Clio 200 Black and White
Where's the best place to get a set of 10mm hubcentric spacers to fit the Clio 182, including longer bolts?
ok, so I just need regular spacers then?
thanks
yes to a degree, just make sure they are 60.1mm bore and if possible with 4x100 PCD, this prevents vibrations.
Or if you really want to fit 10mm hubcentric (they are available) with mounting face you will have to trim your cars hubs faces down to below 10mm.
