I had this problem, turned out to be one of 2 things, timing was out or plugs. I was using NGK switched to iridium power and the problem went away, however i did have my timing checked and it was out due to bent slots on the camshafts (previous owner), so try plugs first.....then get timing checked.
They are brand new plugs 900 miles ago.
I can't see it being the timing as it's only started doing it in the last week!
Idles fine and drives fine it's just that little bit
Just under 2k.
I was thinking more coil pack
Cts,ht leads, crank sensor or throttle body as sometimes that sticks
Thinks it's the idle control valve as I just unpluged it and and plugged it back in unplugged it again and nothing happened, revs didn't even change :s
