i have been told that its not that its hard it juct takes a while to do mine needs doing has done for 4 months dont know if i have the patience but its now leaking water into the car so not much choice plus i can never get chuffin warm
Mine blows out luke warm air even when the car is hot and the rad fan has cut in. Some one mentioned the selector that controls the heat is done by cable which is connected to flaps i might wd40 the cable and hope for the best. Also does every one have a very sensitive engine temp needle as mine is up and down, where it used to stay on half.
You really dont need it in this weather, driving in a wooley hat and gloves is just no good. Reno said it MAY be an airlock and I was told to bleed the system and try and move the expansion tank high up so it is higher than the dashboard. Has anyone tried this?
