should be, just remove the standard air box and that'll leave a big hole for you to cover with the K&N.. might need to take the battery out to remove the standard air box tho....
probably is an air feed mate, maybe even some sort of heat shield. Unfortunatel the pics are never from the actuall car you want it for so for one car those bits may be inculded for fitment but for not for others. same with my piperx. pic showed heat shield and air feed but all i got was the filter and a jubablee clip to hold it on.,..
you should get a carbon fibre mounting thingy that bolts on the same way as the original air filter box, you use the O ring thingy to clamp the ribber bit of the high flow filter itself onto the carbon fibre mould. you should get a black CAF too (mines was back anyway) and that simply clip that on with zip ties. remember and unbolt the engine lift bracket aswell as the filter wont fit on if you dont.
only takes a few minutes in total
and i just noticed you have a 1.8 16v, shoulda checked that before explaining how to fit it onto a 1.2 16v!!! sorry if i lead you astray
It's real easy...a single jubilee clip attaches it to the ICVS and you just have to make sure the seperate idle hose attaches below the main connection (ie there should be two holes in your filter). The large black hard rubber tube is a very poor cold air feed thingi...scrap it, and create your own from 80mm ducting and take the cold feed from just to the side of the rad (similar the the K&N instructions. Cut away the small plastic and it takes a nice feed from just beside the rad right up to the filter..
Brun....do u know where I can get another pair of the two small plastic pipes from for the the fuel vapour me thinks? They snapped when I last took the filter off. Want to buy some b4 I sell the i/k. Cheers
