172 16" sport alloys on a mk2ph1?
Car  ?
finally found some alloys i like....
Will these fit on my 2001 y reg grande with no problems such as rubbing etc?
Thanks guys.
not too much for spacers and bolts, if you want locking wheel nuts tho you'll need longer ones too which will be 40 quid maybe
dont need them mate i got mk2 ph1 with 182 cup alloys on no issues no spacers needed unless u want the wheels to stick out of the archs
I have 172 ph2 wheels on my mk2ph1 atm they rubbed on back so ive put on 3mm spacers which is fine but i need spacers on front as it rubs on full lock and also wheels will look better with 5mm spacers.
im running 5mm spacers on the front where can i get some extended bolts that are 5mm longer than standard bolts?
what spacers as ive just put 5mm ones on the back as they rub on my caliper when there on the front.Where did you get yours from?
