172/182 Inlets - Different?
Car  Sunflower Ph1 172
Was looking at purchasing an RS stamped lower inlet and upper inlet which have already been shot blasted and painted.
However, not sure if the upper inlet is from a 172 or 182.
My car is a Ph1 172.
If I am correct, lower RS inlet will fit as a straight swap?
But are the upper inlets different between 172 and 182? Sure I read somewhere they are, so I assume I could not fit a 182 upper to my Ph1?
If so, how could I tell whether the item I am interested is from 172 or 182 (the seller is not sure).
Ash
Lowers are the same, but uppers are different for the pcd where the throttle body bolts onto the inlet.
Had same issue after my engine build as went from 172 head to 182 and my matched inlets then didn't fit correctly. One of the two mounting bolts at the back won't line up and ends up with an air leak.
You can use the RS Lower Inlet with your 182 upper inlet no problem.
Rs lower inlet fits no problem, just done one on my ph1 end of last year
Ph1 has a different breather system too, this may affect the top inlet aswell as the tb pcv and sensor
Sorry you can use the RS lower inlet with your current upper inlet, which is what I ment to say.
The 182 upper will be different from your current one.
