172 alternator
So would a cup air con delete set up not require the cups alternator is my main query
What about the pure motorsport air con delete? Could I use my ph1 alternator
Dont think you quite understand.
Cup alternator is smaller than a ph1 alt
The ph1 alt is bigger as it runs aircon etc
A ph1 alt will NOT fit in a cup alt cradle
For a air con delete set up u need a 172 cup alternator and its brackets
The end
Got it now?????
Well it doesn't state that on the pure motorsport site
Just checked the fitting guide it's on a ph1 so their kit works with the ph1 alternator that's all I needed to know :)
The 'cup alternator set-up' and the 'PureMotorsport air-con delete kit' are two separate products.
Was just testing the water. Was going to put it on piston heads cause seen a car I wanted but think selling it would be a mistake. Not sure what I'm going to do tbh. Just put solid top mounts on it and an oil and filter change dunno whether to spend more on it or buy something Else.
