172 cam belt change?
Car  V6 Exige, GTR R35
I think my car is about due a cambelt change? 50K!
is there any other belts that i should get changed at the same time? and how much is renault likely to rip me of for working on my pride and joy!!
or any other cheaper places around?
cheers
A cambelt kit - part number 7701474019 is £120.00 + vat and an auxilary belt is £15.99 + vat part number 8200226493. The labour rate with Renault is 2.7 hours to do both belts ( £45 - £70 per hour depending on dealer ) When you fit a timing belt it is essential that you fit new pulleys as well, as the pulleys are made of plastic and if there not renewed they will eventually collapse causing mass damage - the equivalent of a snapped cambelt. Always change the auxilary belt as well as if this snaps they have been known to become entangled in the cambelt and cause the cambelt to jump, again causing massive damage to your engine
My motors got 53k on it and due for a service at 56k, so its probably a good idea for me to do that then? :eek:
How much is this all likely to cost for a main dealer? :cry:
Maindealer between £275 & £400
Timing belt change every 72k or every 5 years - whichever comes 1st. Personally i would do one every 50k are every 3 years due to experience with these snapping.
me too, had the aux belt done a couple of months ago, will need the cambelt done soon... eek!
does changing the cambelt mean i'll have to have the aux belt changed again then?
Here in Australia the owners manuals we get say the belt has to be done at the 60,000 km (37,500 miles) service.
Had an early Honda Civic. The cam-belt snapped. The piston came up and the valves were still down. They didn't fit. Honda decided to add belt replacement to the service schedule.
Cam belts may be cheaper and simpler than chains. But they don't last. So what you saved when you bought the car you then have to pay to regularly replace the belt.
50k for a 172/182 cam belt IMO! see matts comments.... HOW TRUE
you need the special (non american special) tools
I need to get this done ASAP then, i do a bag load of miles each month. On the flip side of the coin, if it did snap, i could always drop a TT engine in, hey matt? No seriously i'm cacking my self, not the best time of year to be shelling out :( but its better than the consequence.
