Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Matt Black sells the kits to do the conversion basically you get the whole looms engine box brakes suspension etc from a 172 for £1.5k+vat.
Then you would realy want to chnage the cambelt clutch bushes top mounts wishbones and you'd have to chnage all the ols whihc is £350 or so extra in parts.
The conversion well tplaces will do it for £500~1k loads of garages won't be interested though its only tunners would would want the trouble to prove they could do it Ktec and GDI have done a conversion though.
Ontop of that you would probably want a disk rear axle although drums are finbe so thats £200 or so second hand and £500 for a new one.
You might also want new brakes lines etc so ds2500 pack with lines is £200 extra.
You can do the conversion yourself if you have the tools time efort and a decient garage but ideally you want a 4 post lift.
Personally its not worth doing either buy a 172 or if you want the sleeper look get a 172 and stick 1.2 body work on it.
