172 cup G meter?
Gallons used from a set point, from what I remember.
Press the button and it should reset.
You can find what's left in the fuel tank by pressing the trip button, and turning the key, IIRC. Then click through a couple of times.
Ahhh right
i looked in the handbook but it's totally different
it says it should show current mpg but it only shows average mpg
I assumed the cups must be different
As mentioned, I will confirm it is a reading of how many gallons you have used since you reset it. Its so that instead of seeing how miles you have used since you filled up/started a road trip you can see how many gallons you have consumed.
But, by all means tell your mates its a G meter. Only advice I would give, is to actually demonstrate it when its gone over 0.1, as you will look a bit silly otherwise.
Ahh yes the 'G' meter.......Is that next to the flux capacitor ?
Is the G meter like the 'G spot' ? If it is you will never find it......
