Is the same as the ph1 gearbox? But different to the normal ph2 172?
Any idea what the difference is between the JC5 129 and the 130 in the later ones?
First gear in the PH1 is no different. I normally just short shift into second as you do.
You sure ? I thought these first gears were the ones to have like a 5% longer ratio than the later RS boxes .. ?
the phase 1 box wont fit the phase 2 ive fitted 2 boxes in my car in 5 yrs, the first replacement was from a normal phase 2 172 and the speedo input/ sensor didnt fit in the box. i believe the phase 2 used there speedo's from the abs, all gears are longer in the phase 1 as i have proven this against phase 2 172/182's and out run them. so if you have a phase 2 clio dont try fitting a phase 1 box it will bolt straight on but your have no speedo.
Yeah you can fit a PH1 box into a cup but not the others
Franx, The 172 Cup uses a JC5 130 from factory. Has your's been replaced with the 129?
The 130 is the strongest box, hence it is also used in the 182, cup and Trophy.
^^ nice one , this i wanted to hear. I'm going to start looking for a Phase 1 box for very cheap if possible and get it reconned. For future purposes. Just went out on an evening thrash and the box is coping but it's not going to last very long anymore i think. Especially when driving with two persons (more weight) and hitting maximum torque on cams , you can hear the box sort of working/squeeling from stress :evil:
Can i use my brand new clutch when changing boxes ? Just had it done ...
This gearbox weakness lark is the biggest myth going imo
Theres a charged ph1 running 300+ and no probs. Countless turbo'd and TB'd ones pumping mid to late 200's again without probs. Its how its looked after and driven thats key imo
i have a spare 172 ph1 box but it has a hole in the casing if you wonna refurb it they should beable to sort that out aswell only want £50 for it.
+1 on the gearbox myth. my car does santa pod and trackdays mainly. It doesn't get driven gently, however i can change gear properly and 18 months on, 180 ftlbs / 240 bhp ish it's still absolutly fine. ( and now on 77k miles)
and the cup has a 129 g/b ( proper cup that is )
It just seems that since the cams came in and i'm making pretty much around the 200 mark that the box is making different noises on full torque than before. Worries me ..
Andy i hope you're right. I have just been reading a lot of negative thing about the RS gearboxes, BUT i do really watch gearchanges, easy on first gear , easy on clutch etc. etc. , just time the right moments to let her go .
So looking another way around is there any gearbox I could fit to my 172 ph1 to make it even quicker ?? From what I read JC5 130 would fit but I would have to give up ABS ? what about better box with ABS ?
I have two Gearboxes striped at the moment as I am going to make a hybrid box out of them and fit a Quaife diff, one From a 2000 ph1 172 and one from a 2003 182, the gear ratios are the same ! it's the Diff that's a different ratio
ph1 172 has a 15,59 the 182 a 15,61, I want the diff ratio from the 182 and the speedo output from the 172,
this will go in my 172 CUP.
