172 cup tie rods and track ends
I believe the first line number you had on the other thread is correct for the 172 cups and 182s.
I can check when I'm back at work Monday as i supply Beaniesport them weekly.
Use FAI 556263 or First Line ss6263 if I remeber correctly and Lemforder ends.
Have a search but 99% these are the correct part numbers.
Ss6263 isn't a first line Partnumber.
The FTR5277 Fordy found is the correct part for cups and 182s. GSF branches will stock these
RENAULT CLIO Left Tie Rod Axle Joint FTR5277 is what I used - The ebay title makes me think they are sided but I just used two FTR5277
