On my cheap ish obd scanner my throttle position was around 4% closed and full throttle reading around 65% wondered if maybe the pedal sensor was on its way out
Will have a look at those this morning any idea where to buy pedal and body new if possible
Cheers for the quick reply
To be honest the pedal and TB are expensive. I would chance my luck with a 2nd hand one first as it's not a massively common fault so you would be unlucky to end up with another faulty one.
HOWEVER that white plug under the fuse box sends so many people down the throttle body and pedal route when it's not.
Get some electrical contact cleaner, give it a proper good spray. Connect it and disconnect it a load of times, spray again and repeat etc to clean it up and then stick it back together.
If you remove the engine bay fuse box cover, clip the relay panel out you will see the connector in the bottom of the fuse box
