172 Droning Noise
Car  Ph1 V6
Got a droning noise coming from my 172, quite like a wind noise. Its at higher rolling speeds but doesn't seem to be throttle related so I'm thinking its prob a wheel bearing? Any ideas?
Sounds like it, get it to a garage to check. Most likly the rear ones in which case new disks as well so that £160 or so with new pads in parts alone.
Cheers mate. Sounds like it could be pricey as it could do with a service as well. Gonna jack it up 2morra and if give them a spin and see if I can hear anything.
What most people do is take the hub off, buy the bearing and get a garage to press it (as you need a hydraulic press) for a fiver or so.
Therefore saving £50 or so in labor.
Guide i done a while ago, on a mk1, but its the same crack
Front Swivel Hub Removal.​
I have assumed you have removed the brake calliper/front brake disk and axel nut.
First undo the nut on the track-rod end, use a ball-joint splitter, else you risk damaging the top of the nut. DON’T use the cheaper versions (pullers) get something similar to this >> http://www.machinemart.co.uk/product...2&r=2076&g=111
Second undo the nut and clamp on the suspension arm to hub and use the ball-joint splitter again, be careful not to damage the rubber gaiter.
I find doing the above awkward, so I usually undo the bolts on the lower arm (wishbone) and keep the lower arm ball-joint inplace.
Finally undo the strut to swivel hub bolts.
Now that everything is undone, all that is needed to do to remove the hub is a ‘gentle’ pull; it can be quite tough because thread locking fluid is applied to the splines, in that case get a rubber mallet and give it a bash. When done it will look like this>
….and the hub (with attached bottom ball joint)
Personally, I use new nut and bolts and thread lock everything where possible, you don’t need to though.
Good luck
(Above guide was done on a MK1 Clio)
