Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
If it were me I would get a KTEC stealth or similar. The Renault exhaust is sh*te ( mine went twice in the space of two months!!) and is also pretty bloody expensive.
Might as well get a stainless one fitted with a lifetime guarantee as it will probablybe cheaper than buying a standard one.
Already looked up the price on dialogies...100odd for the rear and a bit more for the centre section. I would normally say kwikfit too but i recently got badly shaped parts on my clio from there and am also a bit dubious of quality.
The std system is only available as Renault origional. That said, you do not have to go via Renault dealer.
I had mine go about a month ago, took can to local tyre/exhaust place that i've used for years. THey had to get via Renault network - as apparantly none of the patern companies are making 172 systems.
The 172 system as factory fitted is single piece - CAT back. However, the replacement has to be 2 piece as it isn't possible to fit it single - it is fitted at a fairly early stage of car build apparantly. Mine cost me £325, apparantly it is much dearer if you go direct to Renault dealer.
You can get cheaper aftermarket stainless as has been mentioned. I needed my car back on the road as quite as possible, so i just had to go for std as they could get it next day.
I used to own a 172Mk1 a couple of years ago and played around with the exhaust quite a bit - I've got lots of spare parts still littering the house including a couple of hundred mile old standard Renault backbox (still has the Renault stickers on it!), a Devil de-cat (about 1000 miles old) and Devil unsilenced center-section (never fitted). If you live anywhere near Sheffield, just give me the cash to come and meet you somewhere and you can have them for free!
Theres also a powerflo near me...how much would they roughly charge to do a stainless direct copy of the std system do you think? (i'd check myself but they're closed)
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
