172 induction noise
Car  172
will fitting a panel filter to my 172 make a loud induction noise or will i only get induction roar from an induction kit?
You'll get some roar from fitting a panel filter and removing the acoustic valve/airfeed to the airbox. Otherwise you'll need an induction kit.
search it on here theres loads but comes down to 2 options
1) open induction = noise but heat soak
2)closed induction = less noise but no heat soak
panel filters will give a slight noise! the good thing about a phase 1 is you only have to pull the 2 air feeds off and youve got noise for FREE
