172 INLET PORT AND POLISH
Car  CLIO 182
Just been thinking the last few days if its possible to port and polish the inlet manifold on the 172! and if it would maybe b worth it? any1 had this done?. i know its a bit large and curvy shape,but i work in and engineering place,so i should b able to manage it.
I got a 182 n managed to do mine, jus type in port n polish on you tube n there's loads of vids, I did mine with a dremel! Just remember to match all ports to the gaskets and don't polish the inlet too much, hope this helps, if u got the tools u can also bring up the outside to a mirror finish, again I did mine with a dremel n wet n dry sandpaper, must admit it takes a while to do it this way, and u doo get sore fingers too! Let me know how u get on pls mate
Thanks alot 4 the info, will take it off 2mor eve 2 take into work friday. will let u know how it goes,:cool:. does it make much dif performance wise then?
Bit more mid range grunt, not a lot to behonest, but it's a mod u can say u did urself, and us prob reap the benefits after a remap
