172 Model Code
  The Jinx
Anyone tell me what the model code is for these? I want to check up something on dialogys.
mk1 172, mk2 172, 172 Cup please.
TitleDecoding the Oval PlateDescriptionClio codes (for the dialogues) and what the oval plate says about your car.Sent byKDFThanks to edde for this guide, if your car is not listed please send edde a PM
Listed before are some of the codes for the Clio. You need the first 4 letters of the code I'll tried to make in the last colume if you use the dialogues software to find part numbers the model code are. The first column gives you an idea of the car spec (as much as I have at present). The second colume shows the engine code the third colume shows the gearbox code
IE if you want a part number for a Mk 2 2 Dynamic 1.6 16V go to the colume below and see
Mk 2 2 Dynamic 1.6 16V K4M 744 JB3 979 CB1DOF
This means the cars code for the dialgoues is CB1D the engine code is K4M 744 and the gearbox code is JB3 979.
Oval plate info (see lower down this post)
Mk1 1.2 557Y
RN/RT(night and day) 1.1 C571
RL/RN/RT 1.2 C572
RN/RT 1.4 C573
Diesel RN 1.9 C57L
RT 1.8 C57U/C57C
RSI 1.8 C579
Valver 1.8 16V C57D/C575
Williams 2.0 16V C57M
Mk 2 2 Authentique 1.2 CB2DEF
Mk 2 2 Extreme 1.2 16V 3dr D7F 746 JB1 514 CB05CF
1.2 16V 3dr D7F 746 JB1 513
Mk 2 2 Quick shift 5 1.2 16V D4F 712 JH1 004 CB0W0H
1.2 8V CB0FCF
Mk 2 2 Expression 1.4 16V 3dr K4J 710 JB1 CB0PEG
Mk 2 2 Dynamic 1.4 16V K4J 710 JB1 510 CB0POG
Auto 1.4 16V K4J 711 DP0 04 CB1L0A
(Auto) 1.6 16V K4M 745 DP0 062 CB1D0A
Mk 2 2 Dynamic 1.6 16V 3dr K4M 744 JB3 CB1DEF
Mk 2 2 Extreme K9K (65hp) 3dr K9K 704 JB3 969 CB07CF
Mk 2 2 Extreme K9K (80hp) 3dr K9K 702 JC5 128 CB08OF
Mk 2 2 Dynamic 100dci 3dr K9K 712 JR5 CB2G05
Mk 2 1 172 2.0 F4R 730 JC5 089 CB0M
Mk 2 2 Cup 2.0 F4R 732 JC5 129 CB1N0F
Mk 2 2 172 2.0 F4R 732/736 CB1N
Mk2 1 V6 3.0 CB1A
Mk2 2 182 2.0 F4R 738 JC5 130 CB22
Mk2 2 V 6 3.0 CB1U
Oval plate
The oval plate on the Mk2 Clios is found on the bottom the the drivers side pillar down by the sills. It tells you a lot about the car the example below is a 1.4 16V (see the list above for a conversion) the details for cars will be different but you get the idea I hope.
CB0P-is the vehicle type
F003655-is the vehicle fabrication number (manufacture date)
E2-is the equipment level
SAN913-additional limited addition spec
SAN513-additional special edition spec
0V727-paint grade and paint colour
DRAP03-seat upholstery/coverings
HARM01-interior trim colour etc
5-technical specification in relation to coutry. sometimes referred to as
the special features code
ACGK-main options,these are:- A=normal suspension,C=temparate climate,G=non regulated aircon/heating,K=without pollen filter
NRTV-main options,these are:-N=pas,R=without variable shockers,T=without
self level suspension,V=with abs
Other variations of main options are:-M=manual steering,P=variable
pas,D=extremly cold climate,F=normal heating,H=regulated aircon,J=regulated
heating but no aircon,L=with pollen filter,W=without abs,U=with self level
suspension,T=variable shockers.
wot eva the reply was .........hope it helps ?
