S Spiky Car Pug 306 GTI6 & 205 GTI6 Sep 15, 2008 #1 will PH2 fit Ph1? i'm not even sure what they look like
Bash Car vers le haut doigt milieu Sep 15, 2008 #3 Re: 172 PH1 and PH2 same fitting? yes but only with lube
S Spiky Car Pug 306 GTI6 & 205 GTI6 Sep 15, 2008 #4 DOH, sorry guys, was in a world of my own then airbox i've amended the title now
S Spiky Car Pug 306 GTI6 & 205 GTI6 Sep 15, 2008 #5 Re: 172 PH1 and PH2 same fitting? Bash said: yes but only with lube Click to expand... is that renault lube? or will KY be ok :clown:
T Timmay Car RB 200 Cup! Sep 15, 2008 #6 ^ if it was reno stuff itd prob be too expensive - rip off merchants
Christopher ClioSport Club Member Car Z4M Sep 15, 2008 #7 Spiky said: will PH2 fit Ph1? i'm not even sure what they look like Click to expand... Ph1 airbox is a cylinder. Ph2 airbox is square... ish. You can fit one to the other, but you'll need the fittings and fixtures from either a Espace V6 or a Ph1 172, depending on which airbox it is.
Bash Car vers le haut doigt milieu Sep 15, 2008 #8 na its cool, its used to it now just use spit... I have a PH2 airbox if your looking for one.
Christopher ClioSport Club Member Car Z4M Sep 15, 2008 #9 If you have a Ph2 172, use the Ph1 airbox, or one from an Espace V6, they both fit if you buy the bracketry too. Sort of like a DIY Maxogen. A few on here have done it.
S Spiky Car Pug 306 GTI6 & 205 GTI6 Sep 15, 2008 #10 well ideally i want a Ph1, so it's back as it should, as it has some foam filter, and i would prefer the car STD and one just sent me a message saying they have a PH2 hence this post do they look the same???
S Spiky Car Pug 306 GTI6 & 205 GTI6 Sep 15, 2008 #11 ah ok then i'll keep looking for a PH1 one then thanks for the info guys
Christopher ClioSport Club Member Car Z4M Sep 15, 2008 #12 No, completely different. Hold out for a Ph1 airbox. They're the better of the two anyway!
