172 ph1 lowering help
Car  Clio 172 ph1
Hi I wanna lower my car and I'm after advise
just want to make it look better,I was thinking 60mm front and 40mm rear
any one advise me on a good budget set of springs only
thanks
60mm on springs alone is a bit too much on 172s, they start about 30mm lower from the factory than non sports.
Eibach sportlines lower it a nice amount and are still comfy but great for fast driving. Cooksports go a bit lower but I believe are crashier. Then you've got Apex which go the lowest but will make you lose your fillings!
Budget springs will be crap tbh.
Id go with the cooksports, i had the Eibach but it didn't lower the car enough, if you do go for the cooksports then id also fit Cup shocks.
