172 Rear Axle Question!
Car  RS6+ & 40d MSport X5
Will a ph1 172 rear axle fit a 172 cup??
Any parts needing to be swapped over? (bias valve etc)
Gaz
Currently looks like this:
sorry I should have expanded on my reply. you will need to swap the brake pipes etc from the cup to the ph1 beam, brakes are the same just with ABS sensors and rings on the disks.
