172 speedo signal
Hi,
I have a clio 172 which has had a replacement gearbox with no speedo sensor hole. Does anyone know what the pulserate is on these boxes? Ideally I need to know how many pulses the dash sees per revolution of the diff and then I can rig up an alternative sender.
it is done with canbus and magic!! afik takes the speed from all of the sensors and takes an average and than uses that from the abs to the dash.
reason i said 'apparently' is i've heard mixed things about getting the car to get the speed signal from the abs side instead of the speed sensor, few people not been able to get it sorted that way. not even tried it myself so got to say pass on if it can or can't actually be done.
Has anybody managed to successfully do the conversion? I'm interested in getting it done. Thanks
Sent from my SM-G950F using Tapatalk
