172 using all water in 2 days & over heating??
Any signs of leaks? Mine was dropping coolant from the bottom Rad hose.
Have you checked oil to see if there is any coolant mixing? Possible signs of head gasket issues?
I'd be checking for leaks before worrying about anything. Stick an old bit of cardboard under it overnight and you'll see if any water leaks out.
As per Daniel, head gaskets are not common place so more likely you have a small hole in the Rad that when the system builds pressure it pisses out
It's definatly not the head gasket as it all got checked when it was at diamond. Yeah ill have to stick some cardboard under it like dan said.
f**king car :(
