172 Yozza Decat?
When fitting these what is the trick to prevent the emissions light coming on?
Can I just plug the post cat lambda sensor back into the decat and leave it or should I get a blanking plug?
If that fails anyone got any links to cheap code readers?
Had this fitted today, Wow what a noise.
The guy who fitted it said the standard Cat would have to be welded in if i wanted to put it back in place, is that true?
I thought it would be bespoke so to speak just drop the decat out and bolt the cat back in.
This-bit of a pita to do, but no different procedurally to fitting the decat.
