172FF tyre pressures
had a bit of a search and the figures 33 front and 30 rear cropped up a lot. however another thing that was mentioned is 'it depends on what tyres you were running'.
is there a set tyre pressure for a 172FF as per in the manual (I've left my manual at work so can't check)?
and also I'm running exalto's on the front and conti's on the back...would it make a big difference if I deffered form the set std pressures?
