182 alarm help
Car  57 Ibiza Formula Sport
why does my alarm bleep 3 times sometimes when i lock the car and walk away, yet others it doesnt?
It's the ECU thinking the car is still on, it's a common problem...the code is RS+15 that Renault need to be able to fix it under warrenty.
Sure you haven't got something trapped in the door like a seatbelt? It did that to me when I did that once. Although, I'm not exactly sure how many times it beeped but it did. But if it's constantly happening I doubt it's that!
nah there's nothing stuck in the door. i thought at first it was cos i was leaving it in gear, but ive since done that and it hasnt bleeped so god knows! only does it like once every 6 times
You'll find that if you are slow getting out of the car it doesn't do it and it doesn't do it when the boot is open & closed as well.
Mines done it once since owning it but that seemed to be because I shut the door and almost instantly locked it.
This question comes up all the time
http://www.cliosport.net/forum/showthread.php?t=108782
Another common problem is when you lock the car the alarm beeps 2 or 3 times.
Reason: The alarm system has received a signal from the vehicle ECU that the ignition is 'on' causing the alarm to beep. This signal is only received by the alarm for 3 to 4 seconds, after this time has elapsed the alarm stops beeping.
Solution: It can only be resolved at a Renault dealer. Ask the dealer to contact the 'Renault alarm help line' and quote reference
'RS+15'.
Mines done it once or twice since I've owned it, usually if I lock the car really quickly after closing the door.
Sorry to bring up an old post, but mine does this 75% of the time locking it, unless I leave it 30 seconds or more. I understand you can take it to Renault to sort, but does it actually matter at all? ie Is the alarm armed even though it's beeped? As if it is I shall leave it.
Thanks.
Thanks.
Get it fixed might as well.
oooh blast from the past!
i left mine but decided to get it done under warrenty about 3 weeks ago, get it done as it's a £300 job! it's called a UCH that needs replacing, apparently i had no alarm working at all!
Thanks.
Edde, does it actually matter?!? Is it doing any harm?!?
I know you like to try and get people to spend two months wages at Renault, but that wasn't my question lol.
