Does the noise seem to come through your whole dash and make a noise only when the wipers reach the end of each travel before turning back????(kind of high pitched squeek,not like a sticky wiper blade)
Remove the wipers,lift the bonnet and take off the black plastic cover that sits under your wiper blades.Behind this you will see fixing points for the wiper arms to sit on.The passenger side of the car has a small stump if metal sticking out and a rubber grommet attached ,This has either slipped off or is faulty,it causes the metal of the wiper to rub on the wiper arm and send ear peircing sounds through the dash.Slip the gromit back on or ring renault and they will do it
