182 cup packs or not?
1985michael182
So bought a 182 and sold the 172 cup as the 182 is on jenvey with gen90 ecu and loads of other toys fitted.
But.... Is it cup packed?
Can you tell from the Vin number?
I've read the cup packs are 20mm wider track at the front and 10mm at the back.
Is that wider than a normal 182 or than a 172? Is the 172 the same track as the cup packed 182??
I'm all confused
oreA
  BMW M135i; Clio 172
I thought the wider track on 172 Cup and 182 FF cars was due to the different offset wheels.
172, 182 & 172 Cup all have 54mm shock bolt spacing,182 FF have 60mm, if I understand correctly.
imprezaworks
  Mk5 Golf GTI :)
182 ‘cup’
182 ‘cup packed’
60mm.
182 normal 54
172 cup 54
172 normal 54
Phase 1 54
Iirc
  dan's cast offs.
Balance first, dead easy to do. If you want to do it yourself you can get a snail cheap on eBay.
R3k1355
Absolute wetter.
Right so... unless your running 172cup Turinis with wider ofset there's no difference in width. What the benefit of the 60mm spacing over 54mm
Cup shocks are slightly stiffer and cup springs are a touch lower (although many take them out and run lowering springs anyway)
1985michael182
Ah ok so there is a proper difference. Right I'll measure bolt holes when I put new CL5 pads n brembo disks in. It's on gaz golds I think aswell so they are better than cup shocks
