182 Decat only video?
Car  Megane 265 Cup
Anyone got a video anywhere of how a 182 sounds with just a decat on the standard system?
no but thats the sort of thing im also looking for. I have found this...
Other Information That May Be Useful
With most 182 Catback systems you will be looking at a noise level of around about 90-93db. Once Decatted this can add about 3 or 4 db to the volume of the system.
Weight – the standard 182 system weighs 23kg, a YozzaSport system weighs just on 16kg, a saving of 7 kilos over the standard item. Other race systems are lighter, but these systems are obviously not intended for road use.
Doesn't give the standard Db level or level of standard with decat :(
No one got or can find a video of a 182 with decat only?
When i had a decat on a standard system i couldn't tell any change in noise.
Trust me sounds exactly the same as standard, unless you knew you wouldn't be able to tell it was decatted.
Thanks Rollo, guess I will find out soon anyways, my decat will be in the post tomorrow :D
