182 engine problem
  clio 182
Any advice plzzz.............................
This is an ongoing problem that has got worse to the point don't want to take the car out until totally fixed.
Car starts will idle fine the rns really rough, revs drop almost cutting engine out, then engine runs rough, then clears, engine revs go up again to about 1200. Could rn fine for 5mins then starts all over again.
If you try and touch the throttle engine gets worse then clears the minute you take your foot off.
This happens when your driving as well, hot or cold........ Any ideas???
Any lights on the dash?
I'd take the plugs out and check for water in plug wells/corroded plugs first
