182 fueling issue
  clio 182
Hi wondered if anyone has come across this.
my 182 is running rich the short term fuel trim is running at -60! At idle when hot.
Over the past few months its had
New plugs leads and coil pack
New pre cat o2 sensor and now switching as it should
Two new injectors
Car has been problematic to say the least!
Compressions are good timing is spot on and map sensor is reading the same as a vaccum gauge through vairious revs im running out of things to try. Even after reseting the adaptions its still the same.
So any ideas would be appreciated
Cheers binksy
