as per fred.. the boxes are the same fitment, albeit slightly different ratios.
im not sure but the electric speed sensor on a megane jc5 can be removed and replaced with valver mech one.. may be the same story for this.. otherwisse you can invest in a spa electronic speedo for £150 .
if you willie has ABS then no probs the ratio is different in final drive. if your willie doesnt have ABS then it will fit but no speedo . better off trying to find a cup gearbox
