182 ignition fault finding
  clio 182 trophy
Hi there, I am trying to do some fault finding as I am intermittently losing spark. I cannot seem to find any mention of the ignition system in any of the various manuals I have managed to find online. Does anybody know where I can find this? Thanks.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
It’s a waste spark system, so it is very simple:
Power <> switched IGN Relay controlled
Earth <> Chassis GND
Trigger (1-4) <> ECU Controlled
Trigger (2-3) <> ECU Controlled
Now you know what does what, you should be able to test and work out if and where you have a problem.
  clio 182 trophy
I was looking for resistance values to check if the coil is faulty. But it seems I don't to have any power going to the coil. Also there are only three wires to the coil not four. Should there be permanent live to the coil when the ignition is on but not running?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
If it’s a 3 wire setup, then most likely the coil pack itself will GND itself via the mounting points. In that case the pack will be x2 Triggers and x1 Power
