yh unless you have a mate that works at a garage id go for getting a 182 cat and chopping it up.
p.s you couldnt do my a cheeky favour could you? ive done same as you but making my own link pipe up, i need to know the length from flange to flange of the ktec link pipe. couldnt get your tape measure out could ya.
You'll be up against it trying to get a 182 cat to fit. Has been done but its a fair bit longer than the link pipe plus the flange needs to be added and when your cutting you'll be in the 'construction' of the cat.
Far better using a cat from a Vauxhall or a Rover as iirc their quite small on the cat part. still need to knock up the flanges tho.
Try and find a friendly mot tester would probably be your best bet. Ask about
