182 not starting, esp light on
DomP182
  ph1 172, Arctic182
Not driven my 182 for about two weeks and went to start it to take for an MOT but it just clicks and the esp and serv light comes on, not even trying to turn over.
It has a fairly new battery but I've put it on charge and it showed about 11volts, I'm not into electrics but could that be all it is? Oh and the clock has reset.
Any help much appreciated folks.[emoji4]
Sent from my SM-G903F using Tapatalk
  monaco 172
sounds like a flat batery to me.
Battery should float at about 12.6v
Give it a good charge and try again
DomP182
  ph1 172, Arctic182
Really hope it is mate, my bike did the same thing this weekend but that turned out to be the negative terminal working loose
DomP182
  ph1 172, Arctic182
Bit of a pita as I've got all the parts ready to take it to get the belts dephaser etc. done as well as the mot. Don't know why really, not driven it for probably 3 weeks.
  monaco 172
See if it will jump start if youve got some leads if you dont want to wait for the battery to charge
DomP182
  ph1 172, Arctic182
Unbelievably I don't own any jump leads, I'll just be patient
ADS_V6
  172 cup clio v6 st
Has battery got a guarantee
If so take it back if it is faulty afterwards
DomP182
  ph1 172, Arctic182
Right so went out this morning and same thing happened. Interestingly the central locking flashed the hazards but didn't unlock first time and then when I locked it it beeped 3 times
DomP182
  ph1 172, Arctic182
It's a Bosch that I put in around 2 years ago
DomP182
  ph1 172, Arctic182
Could the starter motor be stuck?
DomP182
  ph1 172, Arctic182
Bit of an update, the abs, serv and esp are lit up and not going out I've checked the fuses that are related to them in the passenger side except there is no esp one.
One thing to mention is that I do have a cracked abs ring on the passenger side I need to replace.
JamesBryan
That just means the alarm/central locking has been reset. Mine does it when the battery dies.
Just have to unlock, open the door and then close and lock again.
DomP182
  ph1 172, Arctic182
Problem solved, even an overnight charge wasn't enough. Set of jump leads on and boom. Only left it a few weeks unused, for a fairly new Bosch battery have to wonder if it's knackered.
ADS_V6
  172 cup clio v6 st
take battery back or ring bosch
Serial number will know how old it is for a replacement
DomP182
  ph1 172, Arctic182
Took it in for the belts etc. to be done last night and after a run it seems to be starting fine now so some power is being put back into it but I'll check it when I get it back.
Think it's time to sell unfortunately due to my new van and not using it.
