182 not turning over
Daz...
  Inferno 182 Cup
In 10.5years of ownership I’ve not had to dip into this section as far as I know.
But here we are due to the old car doing old car things:
Right at the end of the video you can hear a sound from something under the bonnet. I’ve slapped a new battery on because the one on it was old anyway, however I’m getting the same result.
Am I right in thinking this could be the starter motor fuse or am I just hoping for a Christmas miracle?!
Any help would be greatly appreciated.
Mr Trailer Man
My 182 did that when the starter relay went.
Absolutely nothing when I turned the key.
In the engine bay fuse box, you'll see 3 brown relays. The middle one is the starter, swap that with the top one which is the fan and see if it does anything.
That noise at the end just sounds like the throttle body shutting off.
Gus
  182Turbo,DCi90
If it’s not the relay could it be the exciter wire?
I reckon this.
If you have skinny wrist you can get your hand down between the exhaust manifold pipes and feel around for the single wire with a spade connector.
I think its the middle 2 pipes of the 4
Gus
  182Turbo,DCi90
But see if you can push start the car first I reckon.
Mr Trailer Man
E and G
Daz...
  Inferno 182 Cup
I’ve just been out and swapped the relays - no change.
Looks like I’m getting under it tomorrow to check the wiring!
  Renault Kardian
That sound is more like the starter trying and failing than a fuse. Starter motor fuses almost never half work, they usually fail completely. Since a new battery made no difference, check the starter solenoid and the main power cable to the starter for corrosion or a loose connection. A single click or short whirr usually points to a tired starter motor or bad earth strap. Given the age, the starter itself is the most likely culprit.
Daz...
  Inferno 182 Cup
Little update on this.
I’ve just come out to the car and it was still doing the same thing, no surprise there.
I turned the ignition on and held it there a few seconds until the starter motor started clicking again, much excitement!
Then I tried again and….
Obviously I’m very happy this has happened, but very aware something is going to happen again at some point.
Darren S
I don't want to piss on your chips, but that was exactly how mine behaved when the starter motor was dying.
Even managed a few weeks of guaranteeing that the car would start - so long as it had chance to cool down. Then that got worse until it got to point where I had to bump-start it to get to the garage.
Definitely sounds like the starter is deed (or very close to it).
Daz...
  Inferno 182 Cup
I can confirm the starter motor is dead. It worked one more time when I picked the wife up from work and then yesterday I tried it and I had a puff of smoke and a burning smell.
A new Bosch one is now on order.
Daz...
  Inferno 182 Cup
So after the new starter motor was fitted it done the same thing. Obviously, much swearing followed this.
I had to go buy some new jump leads as mine seem to have disappeared, once I had the battery earth connected to the engine it fired up first time. This caused massive relief, followed by more swearing at not having done this first 😅
Anyway, I whipped the passenger wheel off and this is what I found..
New Earth strap is now on order 🤦🏻‍♂️
